This software product contains software components that are subject to open
source licenses. Listed below, you will find the open source software
components that are used together with the copyright notices, the applicable
licenses and the original license texts, which may include warranty
disclaimers and an exclusion of liability (third party license documentation).
The source code and other required materials for particular open source
software components incorporated in this software product may be obtained from
the software supplier. The software supplier will provide you with the
respective source code and materials for a charge covering the cost of
performing such distribution (such as the cost of media, and shipping) in
accordance with the terms and conditions of the applicable licenses. You will
receive more information from support@stemmer-imaging.com.
boost (version: 1.72.0)
by: boost project
https://github.com/boostorg/boost/archive/refs/tags/boost-1.72.0.zip
Copyright notices not required by BSL-1.0, otherwise included in license text.
SPDX expression: BSL-1.0 AND BSD-3-Clause AND Zlib
boost (version: 1.72.0) is licensed under the terms of BSL-1.0.
SPDX id: BSL-1.0
Boost Software License - Version 1.0 - August 17th, 2003
Permission is hereby granted, free of charge, to any person or organization
obtaining a copy of the software and accompanying documentation covered by
this license (the "Software") to use, reproduce, display, distribute,
execute, and transmit the Software, and to prepare derivative works of the
Software, and to permit third-parties to whom the Software is furnished to
do so, all subject to the following:
The copyright notices in the Software and this entire statement, including
the above license grant, this restriction and the following disclaimer,
must be included in all copies of the Software, in whole or in part, and
all derivative works of the Software, unless such copies or derivative
works are solely in the form of machine-executable object code generated by
a source language processor.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT
SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE
FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE,
ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
https://github.com/boostorg/boost/blob/boost-1.72.0/LICENSE_1_0.txt
boost (version: 1.72.0) is licensed under the terms of BSD-3-Clause.
SPDX id: BSD-3-Clause
// Copyright 2010-2012, D. E. Shaw Research.
// All rights reserved.
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions are
// met:
// * Redistributions of source code must retain the above copyright
//   notice, this list of conditions, and the following disclaimer.
// * Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions, and the following disclaimer in the
//   documentation and/or other materials provided with the distribution.
// * Neither the name of D. E. Shaw Research nor the names of its
//   contributors may be used to endorse or promote products derived from
//   this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
https://github.com/boostorg/compute/blob/36c89134d4013b2e5e45bc55656a18bd6141995a/include/boost/compute/random/threefry_engine.hpp#L147
boost (version: 1.72.0) is licensed under the terms of Zlib.
SPDX id: Zlib
    Copyright (c) 2001, Daniel C. Nuffer
    This software is provided 'as-is', without any express or implied
    warranty. In no event will the copyright holder be held liable for
    any damages arising from the use of this software.
    Permission is granted to anyone to use this software for any purpose,
    including commercial applications, and to alter it and redistribute
    it freely, subject to the following restrictions:
    1.  The origin of this software must not be misrepresented; you must
        not claim that you wrote the original software. If you use this
        software in a product, an acknowledgment in the product documentation
        would be appreciated but is not required.
    2.  Altered source versions must be plainly marked as such, and must
        not be misrepresented as being the original software.
    3.  This notice may not be removed or altered from any source
        distribution.
https://github.com/boostorg/serialization/blob/f04a8cbe908d577220c1ca1a6a612ae93249ff08/include/boost/archive/impl/basic_xml_grammar.hpp#L29
cryptopp (version: 5.6.3)
by: Wei Dai
https://github.com/weidai11/cryptopp/archive/refs/tags/CRYPTOPP_5_6_3.zip
cryptopp (version: 5.6.3) is licensed under the terms of BSL-1.0.
SPDX id: BSL-1.0
Compilation Copyright (c) 1995-2013 by Wei Dai.  All rights reserved.
This copyright applies only to this software distribution package
as a compilation, and does not imply a copyright on any particular
file in the package.
All individual files in this compilation are placed in the public domain by
Wei Dai and other contributors.
I would like to thank the following authors for placing their works into
the public domain:
Joan Daemen - 3way.cpp
Leonard Janke - cast.cpp, seal.cpp
Steve Reid - cast.cpp
Phil Karn - des.cpp
Andrew M. Kuchling - md2.cpp, md4.cpp
Colin Plumb - md5.cpp
Seal Woods - rc6.cpp
Chris Morgan - rijndael.cpp
Paulo Baretto - rijndael.cpp, skipjack.cpp, square.cpp
Richard De Moliner - safer.cpp
Matthew Skala - twofish.cpp
Kevin Springle - camellia.cpp, shacal2.cpp, ttmac.cpp, whrlpool.cpp, ripemd.cpp
Ronny Van Keer - sha3.cpp
The Crypto++ Library (as a compilation) is currently licensed under the Boost
Software License 1.0 (http://www.boost.org/users/license.html).
https://github.com/weidai11/cryptopp/blob/CRYPTOPP_5_6_3/License.txt
Eigen (version: 3.3.7)
by: Philip Avery, Abraham Bachrach, Sebastien Barthelemy, Carlos Becker, David Benjamin, Cyrille Berger, Armin Berres, Jose Luis Blanco, Mark Borgerding, Romain Bossart, Kolja Brix, Gauthier Brun, Gabriele Buondonno, Philipp Büttgenbach, Thomas Capricelli, Nicolas Carre, Jean Ceccato, Vladimir Chalupecky, Benjamin Chrétien, Andrew Coles, Jeff complexzeros, Everton Constantino, Marton Danoczy, Jeff Dean, Georg Drenkhahn, Christian Ehrlicher, Martinho Fernandes, Daniel Gomez Ferro, Rohit Garg, Mathieu Gautier, Anton Gladky, Stuart Glaser, Marc Glisse, Frederic Gosselin, Christoph Grüninger, Gaël Guennebaud, Philippe Hamelin, Marcus D. Hanwell, David Harmon, Chen-Pang He, Hauke Heibel, Christoph Hertzberg, Pavel Holoborodko, Tim Holy, Intel, Trevor Irons, Benoît Jacob, Bram de Jong, Kibeom Kim, Moritz Klammler, Claas Köhler, Alexey Korepanov, Igor Krivenko, Marijn Kruisselbrink, Abhijit Kundu, Moritz Lenz, Rasmus Munk Larsen, Bo Li, Sebastian Lipponer, Daniel Lowenberg, David J. Luitz, Naumov Maks, Angelos Mantzaflaris, D J Marcin, Konstantinos A. Margaritis, Roger Martin, Ricard Marxer, Vincenzo Di Massa, Christian Mayer, Frank Meier-Dörnberg, Keir Mierle, Laurent Montel, Eamon Nerbonne, Alexander Neundorf, Jason Newton, Jitse Niesen, Desire Nuentsa, Jan Oberländer, Jos van den Oever, Michael Olbrich, Simon Pilgrim, Bjorn Piltz, Benjamin Piwowarski, Zach Ploskey, Giacomo Po, Sergey Popov, Manoj Rajagopalan, Stjepan Rajko, Jure Repinc, Kenneth Frank Riddile, Richard Roberts, Adolfo Rodriguez, Peter Román, Oliver Ruepp, Radu Bogdan Rusu, C. Antonio Sanchez, Guillaume Saupin, Olivier Saut, Benjamin Schindler, Michael Schmidt, Dennis Schridde, Jakob Schwendner, Christian Seiler, Martin Senst, Sameer Sheorey, Andy Somerville, Alex Stapleton, Benoit Steiner, Sven Strothoff, Leszek Swirski, Adam Szalkowski, Silvio Traversaro, Piotr Trojanek, Anthony Truchet, Adolfo Rodriguez Tsourouksdissian, David Tellenbach, James Richard Tyrer, Rhys Ulerich, Henry de Valence, Ingmar Vanhassel, Michiel Van Dyck, Scott Wheeler, Freddie Witherden, Urs Wolfer, Manuel Yguel, Pierre Zoppitelli, Jonas Adler
https://gitlab.com/libeigen/eigen/-/archive/3.3.7/eigen-3.3.7.zip
Copyright (C) 2018 Benoît Jacob, Gaël Guennebaud and contributers (see above).
Eigen (version: 3.3.7) is licensed under the terms of MPL-2.0.
SPDX id: MPL-2.0
Mozilla Public License Version 2.0
1. Definitions
1.1. "Contributor"
    means each individual or legal entity that creates, contributes to
    the creation of, or owns Covered Software.
1.2. "Contributor Version"
    means the combination of the Contributions of others (if any) used
    by a Contributor and that particular Contributor's Contribution.
1.3. "Contribution"
    means Covered Software of a particular Contributor.
1.4. "Covered Software"
    means Source Code Form to which the initial Contributor has attached
    the notice in Exhibit A, the Executable Form of such Source Code
    Form, and Modifications of such Source Code Form, in each case
    including portions thereof.
1.5. "Incompatible With Secondary Licenses"
    means
    (a) that the initial Contributor has attached the notice described
        in Exhibit B to the Covered Software; or
    (b) that the Covered Software was made available under the terms of
        version 1.1 or earlier of the License, but not also under the
        terms of a Secondary License.
1.6. "Executable Form"
    means any form of the work other than Source Code Form.
1.7. "Larger Work"
    means a work that combines Covered Software with other material, in
    a separate file or files, that is not Covered Software.
1.8. "License"
    means this document.
1.9. "Licensable"
    means having the right to grant, to the maximum extent possible,
    whether at the time of the initial grant or subsequently, any and
    all of the rights conveyed by this License.
1.10. "Modifications"
    means any of the following:
    (a) any file in Source Code Form that results from an addition to,
        deletion from, or modification of the contents of Covered
        Software; or
    (b) any new file in Source Code Form that contains any Covered
        Software.
1.11. "Patent Claims" of a Contributor
    means any patent claim(s), including without limitation, method,
    process, and apparatus claims, in any patent Licensable by such
    Contributor that would be infringed, but for the grant of the
    License, by the making, using, selling, offering for sale, having
    made, import, or transfer of either its Contributions or its
    Contributor Version.
1.12. "Secondary License"
    means either the GNU General Public License, Version 2.0, the GNU
    Lesser General Public License, Version 2.1, the GNU Affero General
    Public License, Version 3.0, or any later versions of those
    licenses.
1.13. "Source Code Form"
    means the form of the work preferred for making modifications.
1.14. "You" (or "Your")
    means an individual or a legal entity exercising rights under this
    License. For legal entities, "You" includes any entity that
    controls, is controlled by, or is under common control with You. For
    purposes of this definition, "control" means (a) the power, direct
    or indirect, to cause the direction or management of such entity,
    whether by contract or otherwise, or (b) ownership of more than
    fifty percent (50%) of the outstanding shares or beneficial
    ownership of such entity.
2. License Grants and Conditions
2.1. Grants
Each Contributor hereby grants You a world-wide, royalty-free,
non-exclusive license:
(a) under intellectual property rights (other than patent or trademark)
    Licensable by such Contributor to use, reproduce, make available,
    modify, display, perform, distribute, and otherwise exploit its
    Contributions, either on an unmodified basis, with Modifications, or
    as part of a Larger Work; and
(b) under Patent Claims of such Contributor to make, use, sell, offer
    for sale, have made, import, and otherwise transfer either its
    Contributions or its Contributor Version.
2.2. Effective Date
The licenses granted in Section 2.1 with respect to any Contribution
become effective for each Contribution on the date the Contributor first
distributes such Contribution.
2.3. Limitations on Grant Scope
The licenses granted in this Section 2 are the only rights granted under
this License. No additional rights or licenses will be implied from the
distribution or licensing of Covered Software under this License.
Notwithstanding Section 2.1(b) above, no patent license is granted by a
Contributor:
(a) for any code that a Contributor has removed from Covered Software;
    or
(b) for infringements caused by: (i) Your and any other third party's
    modifications of Covered Software, or (ii) the combination of its
    Contributions with other software (except as part of its Contributor
    Version); or
(c) under Patent Claims infringed by Covered Software in the absence of
    its Contributions.
This License does not grant any rights in the trademarks, service marks,
or logos of any Contributor (except as may be necessary to comply with
the notice requirements in Section 3.4).
2.4. Subsequent Licenses
No Contributor makes additional grants as a result of Your choice to
distribute the Covered Software under a subsequent version of this
License (see Section 10.2) or under the terms of a Secondary License (if
permitted under the terms of Section 3.3).
2.5. Representation
Each Contributor represents that the Contributor believes its
Contributions are its original creation(s) or it has sufficient rights
to grant the rights to its Contributions conveyed by this License.
2.6. Fair Use
This License is not intended to limit any rights You have under
applicable copyright doctrines of fair use, fair dealing, or other
equivalents.
2.7. Conditions
Sections 3.1, 3.2, 3.3, and 3.4 are conditions of the licenses granted
in Section 2.1.
3. Responsibilities
3.1. Distribution of Source Form
All distribution of Covered Software in Source Code Form, including any
Modifications that You create or to which You contribute, must be under
the terms of this License. You must inform recipients that the Source
Code Form of the Covered Software is governed by the terms of this
License, and how they can obtain a copy of this License. You may not
attempt to alter or restrict the recipients' rights in the Source Code
Form.
3.2. Distribution of Executable Form
If You distribute Covered Software in Executable Form then:
(a) such Covered Software must also be made available in Source Code
    Form, as described in Section 3.1, and You must inform recipients of
    the Executable Form how they can obtain a copy of such Source Code
    Form by reasonable means in a timely manner, at a charge no more
    than the cost of distribution to the recipient; and
(b) You may distribute such Executable Form under the terms of this
    License, or sublicense it under different terms, provided that the
    license for the Executable Form does not attempt to limit or alter
    the recipients' rights in the Source Code Form under this License.
3.3. Distribution of a Larger Work
You may create and distribute a Larger Work under terms of Your choice,
provided that You also comply with the requirements of this License for
the Covered Software. If the Larger Work is a combination of Covered
Software with a work governed by one or more Secondary Licenses, and the
Covered Software is not Incompatible With Secondary Licenses, this
License permits You to additionally distribute such Covered Software
under the terms of such Secondary License(s), so that the recipient of
the Larger Work may, at their option, further distribute the Covered
Software under the terms of either this License or such Secondary
License(s).
3.4. Notices
You may not remove or alter the substance of any license notices
(including copyright notices, patent notices, disclaimers of warranty,
or limitations of liability) contained within the Source Code Form of
the Covered Software, except that You may alter any license notices to
the extent required to remedy known factual inaccuracies.
3.5. Application of Additional Terms
You may choose to offer, and to charge a fee for, warranty, support,
indemnity or liability obligations to one or more recipients of Covered
Software. However, You may do so only on Your own behalf, and not on
behalf of any Contributor. You must make it absolutely clear that any
such warranty, support, indemnity, or liability obligation is offered by
You alone, and You hereby agree to indemnify every Contributor for any
liability incurred by such Contributor as a result of warranty, support,
indemnity or liability terms You offer. You may include additional
disclaimers of warranty and limitations of liability specific to any
jurisdiction.
4. Inability to Comply Due to Statute or Regulation
If it is impossible for You to comply with any of the terms of this
License with respect to some or all of the Covered Software due to
statute, judicial order, or regulation then You must: (a) comply with
the terms of this License to the maximum extent possible; and (b)
describe the limitations and the code they affect. Such description must
be placed in a text file included with all distributions of the Covered
Software under this License. Except to the extent prohibited by statute
or regulation, such description must be sufficiently detailed for a
recipient of ordinary skill to be able to understand it.
5. Termination
5.1. The rights granted under this License will terminate automatically
if You fail to comply with any of its terms. However, if You become
compliant, then the rights granted under this License from a particular
Contributor are reinstated (a) provisionally, unless and until such
Contributor explicitly and finally terminates Your grants, and (b) on an
ongoing basis, if such Contributor fails to notify You of the
non-compliance by some reasonable means prior to 60 days after You have
come back into compliance. Moreover, Your grants from a particular
Contributor are reinstated on an ongoing basis if such Contributor
notifies You of the non-compliance by some reasonable means, this is the
first time You have received notice of non-compliance with this License
from such Contributor, and You become compliant prior to 30 days after
Your receipt of the notice.
5.2. If You initiate litigation against any entity by asserting a patent
infringement claim (excluding declaratory judgment actions,
counter-claims, and cross-claims) alleging that a Contributor Version
directly or indirectly infringes any patent, then the rights granted to
You by any and all Contributors for the Covered Software under Section
2.1 of this License shall terminate.
5.3. In the event of termination under Sections 5.1 or 5.2 above, all
end user license agreements (excluding distributors and resellers) which
have been validly granted by You or Your distributors under this License
prior to termination shall survive termination.
*  6. Disclaimer of Warranty                                           *
*  Covered Software is provided under this License on an "as is"       *
*  basis, without warranty of any kind, either expressed, implied, or  *
*  statutory, including, without limitation, warranties that the       *
*  Covered Software is free of defects, merchantable, fit for a        *
*  particular purpose or non-infringing. The entire risk as to the     *
*  quality and performance of the Covered Software is with You.        *
*  Should any Covered Software prove defective in any respect, You     *
*  (not any Contributor) assume the cost of any necessary servicing,   *
*  repair, or correction. This disclaimer of warranty constitutes an   *
*  essential part of this License. No use of any Covered Software is   *
*  authorized under this License except under this disclaimer.         *
*  7. Limitation of Liability                                          *
*  Under no circumstances and under no legal theory, whether tort      *
*  (including negligence), contract, or otherwise, shall any           *
*  Contributor, or anyone who distributes Covered Software as          *
*  permitted above, be liable to You for any direct, indirect,         *
*  special, incidental, or consequential damages of any character      *
*  including, without limitation, damages for lost profits, loss of    *
*  goodwill, work stoppage, computer failure or malfunction, or any    *
*  and all other commercial damages or losses, even if such party      *
*  shall have been informed of the possibility of such damages. This   *
*  limitation of liability shall not apply to liability for death or   *
*  personal injury resulting from such party's negligence to the       *
*  extent applicable law prohibits such limitation. Some               *
*  jurisdictions do not allow the exclusion or limitation of           *
*  incidental or consequential damages, so this exclusion and          *
*  limitation may not apply to You.                                    *
8. Litigation
Any litigation relating to this License may be brought only in the
courts of a jurisdiction where the defendant maintains its principal
place of business and such litigation shall be governed by laws of that
jurisdiction, without reference to its conflict-of-law provisions.
Nothing in this Section shall prevent a party's ability to bring
cross-claims or counter-claims.
9. Miscellaneous
This License represents the complete agreement concerning the subject
matter hereof. If any provision of this License is held to be
unenforceable, such provision shall be reformed only to the extent
necessary to make it enforceable. Any law or regulation which provides
that the language of a contract shall be construed against the drafter
shall not be used to construe this License against a Contributor.
10. Versions of the License
10.1. New Versions
Mozilla Foundation is the license steward. Except as provided in Section
10.3, no one other than the license steward has the right to modify or
publish new versions of this License. Each version will be given a
distinguishing version number.
10.2. Effect of New Versions
You may distribute the Covered Software under the terms of the version
of the License under which You originally received the Covered Software,
or under the terms of any subsequent version published by the license
steward.
10.3. Modified Versions
If you create software not governed by this License, and you want to
create a new license for such software, you may create and use a
modified version of this License if you rename the license and remove
any references to the name of the license steward (except to note that
such modified license differs from this License).
10.4. Distributing Source Code Form that is Incompatible With Secondary
Licenses
If You choose to distribute Source Code Form that is Incompatible With
Secondary Licenses under the terms of this version of the License, the
notice described in Exhibit B of this License must be attached.
Exhibit A - Source Code Form License Notice
  This Source Code Form is subject to the terms of the Mozilla Public
  License, v. 2.0. If a copy of the MPL was not distributed with this
  file, You can obtain one at http://mozilla.org/MPL/2.0/.
If it is not possible or desirable to put the notice in a particular
file, then You may include the notice in a location (such as a LICENSE
file in a relevant directory) where a recipient would be likely to look
for such a notice.
You may add additional accurate notices of copyright ownership.
Exhibit B - "Incompatible With Secondary Licenses" Notice
  This Source Code Form is "Incompatible With Secondary Licenses", as
  defined by the Mozilla Public License, v. 2.0.
https://gitlab.com/libeigen/eigen/-/blob/3.3.7/COPYING.MPL2?ref_type=tags
Eigen (version: 3.3.7) is licensed under the terms of BSD-3-Clause.
 Copyright (c) 2011, Intel Corporation. All rights reserved.
modification,
 are permitted provided that the following conditions are met:
 * Redistributions of source code must retain the above copyright notice, this
   list of conditions and the following disclaimer.
 * Redistributions in binary form must reproduce the above copyright notice,
   this list of conditions and the following disclaimer in the documentation
 * Neither the name of Intel Corporation nor the names of its contributors may
   be used to endorse or promote products derived from this software without
 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
 ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
 WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
 ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
 LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
 ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
https://gitlab.com/libeigen/eigen/-/blob/3.3.7/COPYING.BSD?ref_type=tags
Expat (version: 2.5.0)
by: James Clark
https://github.com/libexpat/libexpat/archive/refs/tags/R_2_5_0.zip
Expat (version: 2.5.0) is licensed under the terms of MIT.
SPDX id: MIT
Copyright (c) 1998-2000 Thai Open Source Software Center Ltd and Clark Cooper
Copyright (c) 2001-2022 Expat maintainers
Permission is hereby granted, free of charge, to any person obtaining
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
the following conditions:
The above copyright notice and this permission notice shall be included
in all copies or substantial portions of the Software.
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
https://github.com/libexpat/libexpat/blob/master/expat/COPYING
FLANN (version: 1.8.4)
by: Marius Muja, David G. Lowe
https://github.com/flann-lib/flann/archive/refs/tags/1.8.4.zip
FLANN (version: 1.8.4) is licensed under the terms of BSD-3-Clause.
The BSD License
Copyright (c) 2008-2011  Marius Muja (mariusm@cs.ubc.ca). All rights reserved.
Copyright (c) 2008-2011  David G. Lowe (lowe@cs.ubc.ca). All rights reserved.
modification, are permitted provided that the following conditions are met:
 * Neither the name of the "University of British Columbia" nor the names of
its contributors may be used to endorse or promote products derived from this
https://github.com/flann-lib/flann/blob/1.8.4/COPYING
GenApi (version: 3.4.2)
by: Fritz Dierks, Hartmut Nebelung
GenApi (version: 3.4.2) is licensed under the terms of GenICam License.
GenICam License
Version 1.0 - October 9th, 2023
Published by EUROPEAN MACHINE VISION ASSOCIATION (EMVA)
(C) 2023 EMVA
No part of this publication may be reproduced in any form, in an electronic
retrieval
system or otherwise, without prior written permission of EMVA.
Table of Contents
History
1 Introduction
2 Overview
3 Rules for Standard Compliancy
4 Rules for Using the Runtime Version of the Reference Implementation
5 Rules for Using the Development Version of the Reference Implementation
6 Rules for Redistributing SFNC or GenTL SFNC
History
Version | Date | Changed by | Change
1.0 | 09.10.2023 | Christoph Zierl, MVTec | Official release based on Version
1.0 of the EMVA GenICam Working Group Rules
1 Introduction
This document describes the GenICam license within the GenICam standard working
group. Note
that chapters 2-6 are an exact copy of the related chapters in the EMVA GenICam
Working
Group Rules document which is part of the EMVA legal envelope for the GenICam
standard,
see https://www.emva.org/standards-technology/genicam/:
* EMVA Standards Development and Approval Procedures
* EMVA IPR1 Policy
* EMVA IPR Committee Rules
* EMVA GenICam Working Group Application Form
* EMVA GenICam Working Group Rules
2 Overview
The goal of GenICam is to provide a generic programming interface for cameras
which is
independent of the cameras interface technology like GigE Vision, USB3 Vision,
CoaXPress,
Camera Link HS, CSI2 or else. GenICam requires that cameras have a low level,
register based
programming interface, and that interface standards define a protocol for
accessing these
registers. All modern interface standards follow this scheme.
GenICam Modules
The GenICam standard consists of several modules according to the main tasks to
be solved:
* GenApi: standardizes the format of a XML based device description file which
describes
how to map high level feature access (e.g. Camera.Gain = 42) by the user to low
level
register accesses (e.g. Camera.WriteReg(0xff1234, 0x2A, 2)).
* SFNC (Standard Features Naming Convention): standardizes names, types, and
behavior
for the most common device features resulting in a plug&play-like
interoperability
between products from different vendors. Part of the SFNC is also the PFNC
(Pixel Format
Naming Convention) which standardizes the memory layout of video data.
* CLProtocol: standardizes the interface of an adapter DLL to permit
interfacing Camera
Link cameras with GenICam.
* FWUpdate: standardizes the firmware update process for devices using GenApi.
* GenTL: standardizes a generic programming interface for transport layers,
which defines
the enumeration, control and data acquisition of cameras. This interface allows
combining drivers and image processing libraries from different vendors.
* GenTL SFNC: standardizes names, types, and behavior for common features of the
transport layer interface.
* GenCP (Generic Control Protocol): standardizes a generic packet-based
protocol for
controlling cameras. It is used to simplify the definition and implementation
of new
transport layer standards.
* GenDC (Generic Data Container): standardizes a portable generic data
container (GenDC)
format. This allows devices to send any form of data in a Transport Layer
Protocol (TLP)
independent format and permits to share a common data container format for all
the TLP
standards.
The GenICam working group also provides a reference implementation for the
GenApi module.
The reference implementation is a collection of software modules which can be
distributed in
two ways: as runtime version or as development version, see Chapters 4 and 5
for more details
about using and redistributing the reference implementation.
The runtime as well as the development version may contain 3rd party modules
which come with
their own license. These licenses override the GenICam license.
Note that GenICam is a B2B industry standard which is mostly used by vendors
under the hood
to provide interoperability between their products. As a consequence of this,
the reference
implementation does not contain any driver and thus cannot be used stand-alone
to control a
camera.
The standard documents are available for free to anybody. Users may download the
latest version of the standard documents from the GenICam website at
www.genicam.org.
Regarding compliancy, the GenICam standard has been divided into four parts:
* GenICam (mainly the modules GenApi and SFNC)
* GenICam TL (mainly the modules GenTL and GenTL SFNC)
* GenICam CP (mainly the module GenCP)
* GenICam DC (mainly the module GenDC)
While the compliancy rules for GenICam (i.e, the modules GenApi and SFNC) are
always
valid, the compliancy rules for GenICam TL, GenICam CP and GenICam DC are only
valid
if applicable.
GenICam Compliancy
The term GenICam compliant is true for:
* Cameras (or other devices) providing a GenICam compliant XML based device
description file and obeying the standards additional rules. In particular, it
must
follow the GenICam Standard Features Naming Convention (SFNC), whenever
applicable or possible.
* Software libraries being able to access GenICam compliant devices.
GenICam TL Compliancy
The term GenICam TL compliant is true for:
* Products that provide a transport layer interface compatible with the
definitions of the
GenTL and the GenTL SFNC modules ("GenICam GenTL Producers").
* Products that can access devices via a GenICam GenTL Producer based on the
definitions
of the GenTL and the GenTL SFNC modules ("GenICam GenTL Consumers")
GenICam CP Compliancy
The term GenICam CP compliant is true for:
* Cameras (or other devices) that support the generic packet-based protocol and
provide
the bootstrap register map as defined in the GenICam GenCP standard.
* Products that can access devices via the generic packet-based protocol and
bootstrap
GenICam DC Compliancy
The term GenICam DC compliant is true for:
* Products that create, transmit, receive, deliver or store GenDC containers as
defined in
the GenICam GenDC standard which meet the requirements given in the "List of
Requirements and Objectives" and respect the related text in the GenDC
specification.
Certification and Logo
In general, the GenICam compliancy is declared by self-certification. The
can provide additional checklists or certification software that have to be
used during the self-
certification procedure. Vendors may use the GenICam logo(s) and use the name
GenICamTM for
advertising GenICam compliant products. In future, additional compliancy
procedures may
become mandatory for new devices such as validation test suites and/or
obligations to
participate at plug-fests.
The runtime version of the reference implementation is available for free to
anybody in binary
format.
Everyone may download the latest version from the GenICam website.
The runtime version is distributed under a modified BSD License (the term
source code below
refers to the header files delivered with the runtime version):
Copyright (c) 2005-<year>, <owner of the software module>
Redistribution and use in source and binary forms, without2 modification, are
permitted
list of
this list of
conditions and the following disclaimer in the documentation and/or other
materials
* Neither the name of the GenICam standard group nor the names of its
contributors may
specific prior
written permission.
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
In contrast to the BSD License the user must not modify the software except the
installation
procedure, see Chapter 5 for more details. This is to make sure only properly
tested and released
GenICam versions are used in the machine vision community and the support
effort is restricted.
Implementation
In order to get access to the development version of the GenICam reference
implementation a
company must become GenICam Working Group member. Application requires the
completion
and submission of the EMVA GenICam Working Group Application Form which can be
found on
www.genicam.org.
GenICam Working Group members get, inter alia, the following benefits:
* Access to code repository, which allows GenICam Working Group members to
download
the source code of the development version of the GenICam reference
implementation
and use it for debugging.
* Access to GenICam Working Group meetings and the GenICam mailing list.
* Technical support from the GenICam community through the GenICam mailing list.
* The company name is listed on the GenICam website as a GenICam Working Group
member.
By registering, the company accepts in particular, without limitation, the
following obligations:
* It must not give the source code of the development version of the GenICam
reference
implementation to any 3rd party.
* All bug fixes and all changes regarding unsupported platforms and compilers
(for which
no official binaries exist yet) shall be submitted to the respective GenICam
module
maintainers for reviewing and testing. Once the code change is in the code
repository,
private builds can be made using the repository code, provided that the
official way to
create a private namespace and private binary names is used. Additionally, the
self-
generated release must clearly indicate the snapshot version used and state
that it is not
an official release.
* Custom builds of the unmodified source of the GenICam reference
implementation may
be re-distributed in binary format only by GenICam Working Group member
companies,
provided that they follow the official mechanism for utilizing private binary
names,
namespaces, and indicate the repository snapshot version of the source code.
* It must submit improvements to the GenICam Working Group which will validate
them
and add them to the next GenICam release in reasonable time.
* For details about the handling of intellectual property please see the EMVA
GenICam
Working Group Application Form.
* Working group members are charged a reasonable admin fee in order to meet the
EMVAs cost for hosting the GenICam standard.
Redistributing (parts of) SFNC or GenTL SFNC without modification, addition or
interpretation, is
allowed as long as it is clearly stated that this is a copy of the GenICam
(GenTL) SFNC standard
document version <x.y> that can be found at www.genicam.org.
https://www.emva.org/standards-technology/genicam/genicam-downloads/
GenX (version: beta5)
by: Tim Bray
http://www.tbray.org/ongoing/genx/
GenX (version: beta5) is licensed under the terms of MIT.
SPDX id: MIT
Copyright (c) Tim Bray and Sun Microsystems, 2004.
http://www.tbray.org/ongoing/genx/COPYING
jsonformoderncpp (version: 3.6.1)
by: Niels Lohmann
https://github.com/nlohmann/json/archive/refs/tags/v3.6.1.zip
jsonformoderncpp (version: 3.6.1) is licensed under the terms of MIT.
SPDX id: MIT
MIT License
Copyright (c) 2013-2022 Niels Lohmann
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
https://github.com/nlohmann/json/blob/v3.6.1/LICENSE.MIT
libpng (version: 1.6.35)
by: Cosmin Truta, Glenn Randers-Pehrson, Andreas Dilger, Guy Eric Schalnat
https://sourceforge.net/projects/libpng/files/libpng16/1.6.35/libpng-1.6.35.tar.gz/download
libpng (version: 1.6.35) is licensed under the terms of Libpng.
SPDX id: Libpng
This copy of the libpng notices is provided for your convenience.  In case of
any discrepancy between this copy and the notices in the file png.h that is
included in the libpng distribution, the latter shall prevail.
COPYRIGHT NOTICE, DISCLAIMER, and LICENSE:
If you modify libpng you may insert additional notices immediately following
this sentence.
This code is released under the libpng license.
libpng versions 1.0.7, July 1, 2000 through 1.6.35, July 15, 2018 are
Copyright (c) 2000-2002, 2004, 2006-2018 Glenn Randers-Pehrson, are
derived from libpng-1.0.6, and are distributed according to the same
disclaimer and license as libpng-1.0.6 with the following individuals
added to the list of Contributing Authors:
   Simon-Pierre Cadieux
   Eric S. Raymond
   Mans Rullgard
   Cosmin Truta
   Gilles Vollant
   James Yu
   Mandar Sahastrabuddhe
   Google Inc.
   Vadim Barkov
and with the following additions to the disclaimer:
   There is no warranty against interference with your enjoyment of the
   library or against infringement.  There is no warranty that our
   efforts or the library will fulfill any of your particular purposes
   or needs.  This library is provided with all faults, and the entire
   risk of satisfactory quality, performance, accuracy, and effort is with
   the user.
Some files in the "contrib" directory and some configure-generated
files that are distributed with libpng have other copyright owners and
are released under other open source licenses.
libpng versions 0.97, January 1998, through 1.0.6, March 20, 2000, are
Copyright (c) 1998-2000 Glenn Randers-Pehrson, are derived from
libpng-0.96, and are distributed according to the same disclaimer and
license as libpng-0.96, with the following individuals added to the list
   Tom Lane
   Willem van Schaik
libpng versions 0.89, June 1996, through 0.96, May 1997, are
Copyright (c) 1996-1997 Andreas Dilger, are derived from libpng-0.88,
and are distributed according to the same disclaimer and license as
libpng-0.88, with the following individuals added to the list of
   John Bowler
   Kevin Bracey
   Sam Bushell
   Magnus Holmgren
   Greg Roelofs
   Tom Tanner
Some files in the "scripts" directory have other copyright owners
but are released under this license.
libpng versions 0.5, May 1995, through 0.88, January 1996, are
Copyright (c) 1995-1996 Guy Eric Schalnat, Group 42, Inc.
For the purposes of this copyright and license, "Contributing Authors"
is defined as the following set of individuals:
   Andreas Dilger
   Dave Martindale
   Guy Eric Schalnat
   Paul Schmidt
   Tim Wegner
The PNG Reference Library is supplied "AS IS".  The Contributing Authors
and Group 42, Inc. disclaim all warranties, expressed or implied,
including, without limitation, the warranties of merchantability and of
fitness for any purpose.  The Contributing Authors and Group 42, Inc.
assume no liability for direct, indirect, incidental, special, exemplary,
or consequential damages, which may result from the use of the PNG
Reference Library, even if advised of the possibility of such damage.
Permission is hereby granted to use, copy, modify, and distribute this
source code, or portions hereof, for any purpose, without fee, subject
  1. The origin of this source code must not be misrepresented.
  2. Altered versions must be plainly marked as such and must not
     be misrepresented as being the original source.
  3. This Copyright notice may not be removed or altered from any
     source or altered source distribution.
The Contributing Authors and Group 42, Inc. specifically permit, without
fee, and encourage the use of this source code as a component to
supporting the PNG file format in commercial products.  If you use this
source code in a product, acknowledgment is not required but would be
appreciated.
END OF COPYRIGHT NOTICE, DISCLAIMER, and LICENSE.
TRADEMARK:
The name "libpng" has not been registered by the Copyright owner
as a trademark in any jurisdiction.  However, because libpng has
been distributed and maintained world-wide, continually since 1995,
the Copyright owner claims "common-law trademark protection" in any
jurisdiction where common-law trademark is recognized.
OSI CERTIFICATION:
Libpng is OSI Certified Open Source Software.  OSI Certified Open Source is
a certification mark of the Open Source Initiative. OSI has not addressed
the additional disclaimers inserted at version 1.0.7.
EXPORT CONTROL:
The Copyright owner believes that the Export Control Classification
Number (ECCN) for libpng is EAR99, which means not subject to export
controls or International Traffic in Arms Regulations (ITAR) because
it is open source, publicly available software, that does not contain
any encryption software.  See the EAR, paragraphs 734.3(b)(3) and
734.7(b).
glennrp at users.sourceforge.net
July 15, 2018
https://sourceforge.net/projects/libpng/files/libpng16/1.6.35/libpng-1.6.35-LICENSE.txt
libtiff (version: 4.0.9)
by: Sam Leffler
https://gitlab.com/libtiff/libtiff/-/tree/v4.0.9?ref_type=tags
libtiff (version: 4.0.9) is licensed under the terms of libtiff.
SPDX id: libtiff
Copyright (c) 1988-1997 Sam Leffler
Copyright (c) 1991-1997 Silicon Graphics, Inc.
Permission to use, copy, modify, distribute, and sell this software and
its documentation for any purpose is hereby granted without fee, provided
that (i) the above copyright notices and this permission notice appear in
all copies of the software and related documentation, and (ii) the names of
Sam Leffler and Silicon Graphics may not be used in any advertising or
publicity relating to the software without the specific, prior written
permission of Sam Leffler and Silicon Graphics.
THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
OF THIS SOFTWARE.
https://gitlab.com/libtiff/libtiff/-/blob/v4.0.9/COPYRIGHT?ref_type=tags
log4cpp (version: 1.0.0)
by: Bastiaan Bakker
https://sourceforge.net/projects/log4cpp/files/log4cpp-1.0.x%20%28old%29/log4cpp-1.0/log4cpp-1.0.tar.gz/download
Copyright (C) 2000-2002 LifeLine Networks bv, Copyright (C) 2000-2002 Bastiaan Bakker
log4cpp (version: 1.0.0) is licensed under the terms of LGPL-2.1.
SPDX id: LGPL-2.1-or-later
                  GNU LESSER GENERAL PUBLIC LICENSE
                       Version 2.1, February 1999
 Copyright (C) 1991, 1999 Free Software Foundation, Inc.
 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
 Everyone is permitted to copy and distribute verbatim copies
 of this license document, but changing it is not allowed.
[This is the first released version of the Lesser GPL.  It also counts
 as the successor of the GNU Library Public License, version 2, hence
 the version number 2.1.]
                            Preamble
  The licenses for most software are designed to take away your
freedom to share and change it.  By contrast, the GNU General Public
Licenses are intended to guarantee your freedom to share and change
free software--to make sure the software is free for all its users.
  This license, the Lesser General Public License, applies to some
specially designated software packages--typically libraries--of the
Free Software Foundation and other authors who decide to use it.  You
can use it too, but we suggest you first think carefully about whether
this license or the ordinary General Public License is the better
strategy to use in any particular case, based on the explanations below.
  When we speak of free software, we are referring to freedom of use,
not price.  Our General Public Licenses are designed to make sure that
you have the freedom to distribute copies of free software (and charge
for this service if you wish); that you receive source code or can get
it if you want it; that you can change the software and use pieces of
it in new free programs; and that you are informed that you can do
these things.
  To protect your rights, we need to make restrictions that forbid
distributors to deny you these rights or to ask you to surrender these
rights.  These restrictions translate to certain responsibilities for
you if you distribute copies of the library or if you modify it.
  For example, if you distribute copies of the library, whether gratis
or for a fee, you must give the recipients all the rights that we gave
you.  You must make sure that they, too, receive or can get the source
code.  If you link other code with the library, you must provide
complete object files to the recipients, so that they can relink them
with the library after making changes to the library and recompiling
it.  And you must show them these terms so they know their rights.
  We protect your rights with a two-step method: (1) we copyright the
library, and (2) we offer you this license, which gives you legal
permission to copy, distribute and/or modify the library.
  To protect each distributor, we want to make it very clear that
there is no warranty for the free library.  Also, if the library is
modified by someone else and passed on, the recipients should know
that what they have is not the original version, so that the original
author's reputation will not be affected by problems that might be
introduced by others.
  Finally, software patents pose a constant threat to the existence of
any free program.  We wish to make sure that a company cannot
effectively restrict the users of a free program by obtaining a
restrictive license from a patent holder.  Therefore, we insist that
any patent license obtained for a version of the library must be
consistent with the full freedom of use specified in this license.
  Most GNU software, including some libraries, is covered by the
ordinary GNU General Public License.  This license, the GNU Lesser
General Public License, applies to certain designated libraries, and
is quite different from the ordinary General Public License.  We use
this license for certain libraries in order to permit linking those
libraries into non-free programs.
  When a program is linked with a library, whether statically or using
a shared library, the combination of the two is legally speaking a
combined work, a derivative of the original library.  The ordinary
General Public License therefore permits such linking only if the
entire combination fits its criteria of freedom.  The Lesser General
Public License permits more lax criteria for linking other code with
the library.
  We call this license the "Lesser" General Public License because it
does Less to protect the user's freedom than the ordinary General
Public License.  It also provides other free software developers Less
of an advantage over competing non-free programs.  These disadvantages
are the reason we use the ordinary General Public License for many
libraries.  However, the Lesser license provides advantages in certain
special circumstances.
  For example, on rare occasions, there may be a special need to
encourage the widest possible use of a certain library, so that it becomes
a de-facto standard.  To achieve this, non-free programs must be
allowed to use the library.  A more frequent case is that a free
library does the same job as widely used non-free libraries.  In this
case, there is little to gain by limiting the free library to free
software only, so we use the Lesser General Public License.
  In other cases, permission to use a particular library in non-free
programs enables a greater number of people to use a large body of
free software.  For example, permission to use the GNU C Library in
non-free programs enables many more people to use the whole GNU
operating system, as well as its variant, the GNU/Linux operating
system.
  Although the Lesser General Public License is Less protective of the
users' freedom, it does ensure that the user of a program that is
linked with the Library has the freedom and the wherewithal to run
that program using a modified version of the Library.
  The precise terms and conditions for copying, distribution and
modification follow.  Pay close attention to the difference between a
"work based on the library" and a "work that uses the library".  The
former contains code derived from the library, whereas the latter must
be combined with the library in order to run.
   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
  0. This License Agreement applies to any software library or other
program which contains a notice placed by the copyright holder or
other authorized party saying it may be distributed under the terms of
this Lesser General Public License (also called "this License").
Each licensee is addressed as "you".
  A "library" means a collection of software functions and/or data
prepared so as to be conveniently linked with application programs
(which use some of those functions and data) to form executables.
  The "Library", below, refers to any such software library or work
which has been distributed under these terms.  A "work based on the
Library" means either the Library or any derivative work under
copyright law: that is to say, a work containing the Library or a
portion of it, either verbatim or with modifications and/or translated
straightforwardly into another language.  (Hereinafter, translation is
included without limitation in the term "modification".)
  "Source code" for a work means the preferred form of the work for
making modifications to it.  For a library, complete source code means
all the source code for all modules it contains, plus any associated
interface definition files, plus the scripts used to control compilation
and installation of the library.
  Activities other than copying, distribution and modification are not
covered by this License; they are outside its scope.  The act of
running a program using the Library is not restricted, and output from
such a program is covered only if its contents constitute a work based
on the Library (independent of the use of the Library in a tool for
writing it).  Whether that is true depends on what the Library does
and what the program that uses the Library does.
  1. You may copy and distribute verbatim copies of the Library's
complete source code as you receive it, in any medium, provided that
you conspicuously and appropriately publish on each copy an
appropriate copyright notice and disclaimer of warranty; keep intact
all the notices that refer to this License and to the absence of any
warranty; and distribute a copy of this License along with the
Library.
  You may charge a fee for the physical act of transferring a copy,
and you may at your option offer warranty protection in exchange for a
fee.
  2. You may modify your copy or copies of the Library or any portion
of it, thus forming a work based on the Library, and copy and
distribute such modifications or work under the terms of Section 1
above, provided that you also meet all of these conditions:
    a) The modified work must itself be a software library.
    b) You must cause the files modified to carry prominent notices
    stating that you changed the files and the date of any change.
    c) You must cause the whole of the work to be licensed at no
    charge to all third parties under the terms of this License.
    d) If a facility in the modified Library refers to a function or a
    table of data to be supplied by an application program that uses
    the facility, other than as an argument passed when the facility
    is invoked, then you must make a good faith effort to ensure that,
    in the event an application does not supply such function or
    table, the facility still operates, and performs whatever part of
    its purpose remains meaningful.
    (For example, a function in a library to compute square roots has
    a purpose that is entirely well-defined independent of the
    application.  Therefore, Subsection 2d requires that any
    application-supplied function or table used by this function must
    be optional: if the application does not supply it, the square
    root function must still compute square roots.)
These requirements apply to the modified work as a whole.  If
identifiable sections of that work are not derived from the Library,
and can be reasonably considered independent and separate works in
themselves, then this License, and its terms, do not apply to those
sections when you distribute them as separate works.  But when you
distribute the same sections as part of a whole which is a work based
on the Library, the distribution of the whole must be on the terms of
this License, whose permissions for other licensees extend to the
entire whole, and thus to each and every part regardless of who wrote
it.
Thus, it is not the intent of this section to claim rights or contest
your rights to work written entirely by you; rather, the intent is to
exercise the right to control the distribution of derivative or
collective works based on the Library.
In addition, mere aggregation of another work not based on the Library
with the Library (or with a work based on the Library) on a volume of
a storage or distribution medium does not bring the other work under
the scope of this License.
  3. You may opt to apply the terms of the ordinary GNU General Public
License instead of this License to a given copy of the Library.  To do
this, you must alter all the notices that refer to this License, so
that they refer to the ordinary GNU General Public License, version 2,
instead of to this License.  (If a newer version than version 2 of the
ordinary GNU General Public License has appeared, then you can specify
that version instead if you wish.)  Do not make any other change in
these notices.
  Once this change is made in a given copy, it is irreversible for
that copy, so the ordinary GNU General Public License applies to all
subsequent copies and derivative works made from that copy.
  This option is useful when you wish to copy part of the code of
the Library into a program that is not a library.
  4. You may copy and distribute the Library (or a portion or
derivative of it, under Section 2) in object code or executable form
under the terms of Sections 1 and 2 above provided that you accompany
it with the complete corresponding machine-readable source code, which
must be distributed under the terms of Sections 1 and 2 above on a
medium customarily used for software interchange.
  If distribution of object code is made by offering access to copy
from a designated place, then offering equivalent access to copy the
source code from the same place satisfies the requirement to
distribute the source code, even though third parties are not
compelled to copy the source along with the object code.
  5. A program that contains no derivative of any portion of the
Library, but is designed to work with the Library by being compiled or
linked with it, is called a "work that uses the Library".  Such a
work, in isolation, is not a derivative work of the Library, and
therefore falls outside the scope of this License.
  However, linking a "work that uses the Library" with the Library
creates an executable that is a derivative of the Library (because it
contains portions of the Library), rather than a "work that uses the
library".  The executable is therefore covered by this License.
Section 6 states terms for distribution of such executables.
  When a "work that uses the Library" uses material from a header file
that is part of the Library, the object code for the work may be a
derivative work of the Library even though the source code is not.
Whether this is true is especially significant if the work can be
linked without the Library, or if the work is itself a library.  The
threshold for this to be true is not precisely defined by law.
  If such an object file uses only numerical parameters, data
structure layouts and accessors, and small macros and small inline
functions (ten lines or less in length), then the use of the object
file is unrestricted, regardless of whether it is legally a derivative
work.  (Executables containing this object code plus portions of the
Library will still fall under Section 6.)
  Otherwise, if the work is a derivative of the Library, you may
distribute the object code for the work under the terms of Section 6.
Any executables containing that work also fall under Section 6,
whether or not they are linked directly with the Library itself.
  6. As an exception to the Sections above, you may also combine or
link a "work that uses the Library" with the Library to produce a
work containing portions of the Library, and distribute that work
under terms of your choice, provided that the terms permit
modification of the work for the customer's own use and reverse
engineering for debugging such modifications.
  You must give prominent notice with each copy of the work that the
Library is used in it and that the Library and its use are covered by
this License.  You must supply a copy of this License.  If the work
during execution displays copyright notices, you must include the
copyright notice for the Library among them, as well as a reference
directing the user to the copy of this License.  Also, you must do one
of these things:
    a) Accompany the work with the complete corresponding
    machine-readable source code for the Library including whatever
    changes were used in the work (which must be distributed under
    Sections 1 and 2 above); and, if the work is an executable linked
    with the Library, with the complete machine-readable "work that
    uses the Library", as object code and/or source code, so that the
    user can modify the Library and then relink to produce a modified
    executable containing the modified Library.  (It is understood
    that the user who changes the contents of definitions files in the
    Library will not necessarily be able to recompile the application
    to use the modified definitions.)
    b) Use a suitable shared library mechanism for linking with the
    Library.  A suitable mechanism is one that (1) uses at run time a
    copy of the library already present on the user's computer system,
    rather than copying library functions into the executable, and (2)
    will operate properly with a modified version of the library, if
    the user installs one, as long as the modified version is
    interface-compatible with the version that the work was made with.
    c) Accompany the work with a written offer, valid for at
    least three years, to give the same user the materials
    specified in Subsection 6a, above, for a charge no more
    than the cost of performing this distribution.
    d) If distribution of the work is made by offering access to copy
    from a designated place, offer equivalent access to copy the above
    specified materials from the same place.
    e) Verify that the user has already received a copy of these
    materials or that you have already sent this user a copy.
  For an executable, the required form of the "work that uses the
Library" must include any data and utility programs needed for
reproducing the executable from it.  However, as a special exception,
the materials to be distributed need not include anything that is
normally distributed (in either source or binary form) with the major
components (compiler, kernel, and so on) of the operating system on
which the executable runs, unless that component itself accompanies
the executable.
  It may happen that this requirement contradicts the license
restrictions of other proprietary libraries that do not normally
accompany the operating system.  Such a contradiction means you cannot
use both them and the Library together in an executable that you
distribute.
  7. You may place library facilities that are a work based on the
Library side-by-side in a single library together with other library
facilities not covered by this License, and distribute such a combined
library, provided that the separate distribution of the work based on
the Library and of the other library facilities is otherwise
permitted, and provided that you do these two things:
    a) Accompany the combined library with a copy of the same work
    based on the Library, uncombined with any other library
    facilities.  This must be distributed under the terms of the
    Sections above.
    b) Give prominent notice with the combined library of the fact
    that part of it is a work based on the Library, and explaining
    where to find the accompanying uncombined form of the same work.
  8. You may not copy, modify, sublicense, link with, or distribute
the Library except as expressly provided under this License.  Any
attempt otherwise to copy, modify, sublicense, link with, or
distribute the Library is void, and will automatically terminate your
rights under this License.  However, parties who have received copies,
or rights, from you under this License will not have their licenses
terminated so long as such parties remain in full compliance.
  9. You are not required to accept this License, since you have not
signed it.  However, nothing else grants you permission to modify or
distribute the Library or its derivative works.  These actions are
prohibited by law if you do not accept this License.  Therefore, by
modifying or distributing the Library (or any work based on the
Library), you indicate your acceptance of this License to do so, and
all its terms and conditions for copying, distributing or modifying
the Library or works based on it.
  10. Each time you redistribute the Library (or any work based on the
Library), the recipient automatically receives a license from the
original licensor to copy, distribute, link with or modify the Library
subject to these terms and conditions.  You may not impose any further
restrictions on the recipients' exercise of the rights granted herein.
You are not responsible for enforcing compliance by third parties with
this License.
  11. If, as a consequence of a court judgment or allegation of patent
infringement or for any other reason (not limited to patent issues),
conditions are imposed on you (whether by court order, agreement or
otherwise) that contradict the conditions of this License, they do not
excuse you from the conditions of this License.  If you cannot
distribute so as to satisfy simultaneously your obligations under this
License and any other pertinent obligations, then as a consequence you
may not distribute the Library at all.  For example, if a patent
license would not permit royalty-free redistribution of the Library by
all those who receive copies directly or indirectly through you, then
the only way you could satisfy both it and this License would be to
refrain entirely from distribution of the Library.
If any portion of this section is held invalid or unenforceable under any
particular circumstance, the balance of the section is intended to apply,
and the section as a whole is intended to apply in other circumstances.
It is not the purpose of this section to induce you to infringe any
patents or other property right claims or to contest validity of any
such claims; this section has the sole purpose of protecting the
integrity of the free software distribution system which is
implemented by public license practices.  Many people have made
generous contributions to the wide range of software distributed
through that system in reliance on consistent application of that
system; it is up to the author/donor to decide if he or she is willing
to distribute software through any other system and a licensee cannot
impose that choice.
This section is intended to make thoroughly clear what is believed to
be a consequence of the rest of this License.
  12. If the distribution and/or use of the Library is restricted in
certain countries either by patents or by copyrighted interfaces, the
original copyright holder who places the Library under this License may add
an explicit geographical distribution limitation excluding those countries,
so that distribution is permitted only in or among countries not thus
excluded.  In such case, this License incorporates the limitation as if
written in the body of this License.
  13. The Free Software Foundation may publish revised and/or new
versions of the Lesser General Public License from time to time.
Such new versions will be similar in spirit to the present version,
but may differ in detail to address new problems or concerns.
Each version is given a distinguishing version number.  If the Library
specifies a version number of this License which applies to it and
"any later version", you have the option of following the terms and
conditions either of that version or of any later version published by
the Free Software Foundation.  If the Library does not specify a
license version number, you may choose any version ever published by
  14. If you wish to incorporate parts of the Library into other free
programs whose distribution conditions are incompatible with these,
write to the author to ask for permission.  For software which is
copyrighted by the Free Software Foundation, write to the Free
Software Foundation; we sometimes make exceptions for this.  Our
decision will be guided by the two goals of preserving the free status
of all derivatives of our free software and of promoting the sharing
and reuse of software generally.
                            NO WARRANTY
  15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY
KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE
LIBRARY IS WITH YOU.  SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME
THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
  16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU
FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR
CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE
LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING
RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A
FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF
SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
DAMAGES.
                     END OF TERMS AND CONDITIONS
           How to Apply These Terms to Your New Libraries
  If you develop a new library, and you want it to be of the greatest
possible use to the public, we recommend making it free software that
everyone can redistribute and change.  You can do so by permitting
redistribution under these terms (or, alternatively, under the terms of the
ordinary General Public License).
  To apply these terms, attach the following notices to the library.  It is
safest to attach them to the start of each source file to most effectively
convey the exclusion of warranty; and each file should have at least the
"copyright" line and a pointer to where the full notice is found.
    <one line to give the library's name and a brief idea of what it does.>
    Copyright (C) <year>  <name of author>
    This library is free software; you can redistribute it and/or
    modify it under the terms of the GNU Lesser General Public
    License as published by the Free Software Foundation; either
    version 2.1 of the License, or (at your option) any later version.
    This library is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    Lesser General Public License for more details.
    You should have received a copy of the GNU Lesser General Public
    License along with this library; if not, write to the Free Software
    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301
USA
Also add information on how to contact you by electronic and paper mail.
You should also get your employer (if you work as a programmer) or your
school, if any, to sign a "copyright disclaimer" for the library, if
necessary.  Here is a sample; alter the names:
  Yoyodyne, Inc., hereby disclaims all copyright interest in the
  library `Frob' (a library for tweaking knobs) written by James Random Hacker.
  <signature of Ty Coon>, 1 April 1990
  Ty Coon, President of Vice
That's all there is to it!
https://log4cpp.sourceforge.net/#license
MathParser (version: 0.03b.0)
by: Kirill Zaborski
http://kirya.narod.ru/files/mathparser_0.03.zip
Copyright (C) 2003 Kirill Zaborsk
MathParser (version: 0.03b.0) is licensed under the terms of MIT.
SPDX id: MIT
Copyright <YEAR> <COPYRIGHT HOLDER>
Permission is hereby granted, free of charge, to any person obtaining a copy of
this software and associated documentation files (the Software), to deal in the
Software without restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the
Software, and to permit persons to whom the Software is furnished to do so,
THE SOFTWARE IS PROVIDED AS IS, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
SOFTWARE.
https://opensource.org/license/MIT
miniz (version: 1.14.0)
by: Rich Geldreich
https://github.com/richgel999/miniz/archive/refs/tags/v114.zip
miniz (version: 1.14.0) is licensed under the terms of MIT.
SPDX id: MIT
Copyright 2013-2014 RAD Game Tools and Valve Software
Copyright 2010-2014 Rich Geldreich and Tenacious Software LLC
All Rights Reserved.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
THE SOFTWARE.
https://github.com/richgel999/miniz/blob/293d4db1b7d0ffee9756d035b9ac6f7431ef8492/LICENSE
nanoflann (version: 1.3.1)
by: Marius Muja, David G. Lowe, Jose L. Blanco
https://github.com/jlblancoc/nanoflann/archive/refs/tags/v1.3.1.zip
nanoflann (version: 1.3.1) is licensed under the terms of BSD-2-Clause.
SPDX id: BSD-2-Clause
Software License Agreement (BSD License)
Copyright 2008-2009  Marius Muja (mariusm@cs.ubc.ca). All rights reserved.
Copyright 2008-2009  David G. Lowe (lowe@cs.ubc.ca). All rights reserved.
Copyright 2011 Jose L. Blanco (joseluisblancoc@gmail.com). All rights reserved.
THE BSD LICENSE
Redistribution and use in source and binary forms, with or without
are met:
1. Redistributions of source code must retain the above copyright
   notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
   notice, this list of conditions and the following disclaimer in the
   documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
https://github.com/jlblancoc/nanoflann/blob/v1.3.1/COPYING
openjpeg (version: 1.2)
by: Benoit Macq, Antonin Descampe, Francois-Olivier Devaux, Herve Drolon, Yannick Verschueren, David Janssens
https://github.com/uclouvain/openjpeg/tree/version.1.2
openjpeg (version: 1.2) is licensed under the terms of BSD-2-Clause.
Copyright (c) 2002-2007, Communications and Remote Sensing Laboratory,
Universite catholique de Louvain (UCL), Belgium
Copyright (c) 2002-2007, Professor Benoit Macq
Copyright (c) 2001-2003, David Janssens
Copyright (c) 2002-2003, Yannick Verschueren
Copyright (c) 2003-2007, Francois-Olivier Devaux and Antonin Descampe
Copyright (c) 2005, Herve Drolon, FreeImage Team
are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS `AS IS'
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
https://github.com/uclouvain/openjpeg/blob/version.1.2/license.txt
pcl (version: 1.12.0)
by: Open Perception, Inc.
https://github.com/PointCloudLibrary/pcl/tree/pcl-1.12.0
pcl (version: 1.12.0) is licensed under the terms of BSD-3-Clause.
SPDX id: BSD-3-Clause
Point Cloud Library (PCL) - www.pointclouds.org
Copyright (c) 2009-2012, Willow Garage, Inc.
Copyright (c) 2012-, Open Perception, Inc.
Copyright (c) XXX, respective authors.
are met:
   copyright notice, this list of conditions and the following
   disclaimer in the documentation and/or other materials provided
 * Neither the name of the copyright holder(s) nor the names of its
   from this software without specific prior written permission.
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
https://github.com/PointCloudLibrary/pcl/blob/pcl-1.12.0/LICENSE.txt
PCRE2 (version: 10.42.0)
by: Philip Hazel
https://github.com/PCRE2Project/pcre2/releases/download/pcre2-10.42/pcre2-10.42.zip
PCRE2 (version: 10.42.0) is licensed under the terms of BSD-3-Clause.
PCRE2 LICENCE
PCRE2 is a library of functions to support regular expressions whose syntax
and semantics are as close as possible to those of the Perl 5 language.
Releases 10.00 and above of PCRE2 are distributed under the terms of the "BSD"
licence, as specified below, with one exemption for certain binary
redistributions. The documentation for PCRE2, supplied in the "doc" directory,
is distributed under the same terms as the software itself. The data in the
testdata directory is not copyrighted and is in the public domain.
The basic library functions are written in C and are freestanding. Also
included in the distribution is a just-in-time compiler that can be used to
optimize pattern matching. This is an optional feature that can be omitted when
the library is built.
THE BASIC LIBRARY FUNCTIONS
Written by:       Philip Hazel
Email local part: Philip.Hazel
Email domain:     gmail.com
Retired from University of Cambridge Computing Service,
Cambridge, England.
Copyright (c) 1997-2021 University of Cambridge
PCRE2 JUST-IN-TIME COMPILATION SUPPORT
Written by:       Zoltan Herczeg
Email local part: hzmester
Email domain:     freemail.hu
Copyright(c) 2010-2021 Zoltan Herczeg
STACK-LESS JUST-IN-TIME COMPILER
Copyright(c) 2009-2021 Zoltan Herczeg
THE "BSD" LICENCE
    * Redistributions of source code must retain the above copyright notices,
      notices, this list of conditions and the following disclaimer in the
    * Neither the name of the University of Cambridge nor the names of any
EXEMPTION FOR BINARY LIBRARY-LIKE PACKAGES
The second condition in the BSD licence (covering binary redistributions) does
not apply all the way down a chain of software. If binary package A includes
PCRE2, it must respect the condition, but if package B is software that
includes package A, the condition is not imposed on package B unless it uses
PCRE2 independently.
End
https://github.com/PCRE2Project/pcre2/blob/pcre2-10.42/LICENCE
rapidxml (version: 1.13)
by: Marcin Kalicinski
https://sourceforge.net/project/platformdownload.php?group_id=189621&sel_platform=1227
SPDX expression: BSL-1.0 OR MIT
BSL-1.0 is not used to license rapidxml (version: 1.13) but added for reference
(see license alternatives expression).
SPDX id: BSL-1.0
Copyright (c) 2006, 2007 Marcin Kalicinski
Permission is hereby granted, free of charge, to any person or organization
obtaining a copy of the software and accompanying documentation covered by
this license (the "Software") to use, reproduce, display, distribute,
execute, and transmit the Software, and to prepare derivative works of the
Software, and to permit third-parties to whom the Software is furnished to
do so, all subject to the following:
The copyright notices in the Software and this entire statement, including
the above license grant, this restriction and the following disclaimer,
must be included in all copies of the Software, in whole or in part, and
all derivative works of the Software, unless such copies or derivative
works are solely in the form of machine-executable object code generated by
a source language processor.
FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT
SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE
FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE,
ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
https://rapidxml.sourceforge.net/license.txt
rapidxml (version: 1.13) is licensed under the terms of MIT.
SPDX id: MIT
copies
of the Software, and to permit persons to whom the Software is furnished to do
so,
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
IN THE SOFTWARE.
sqlite (version: 3.7.16.1)
by: Hipp, Wyrick & Company, Inc
https://github.com/sqlite/sqlite/archive/refs/tags/version-3.7.16.1.zip
sqlite (version: 3.7.16.1) is licensed under the terms of blessing.
SPDX id: blessing
The author disclaims copyright to this source code. In place of a legal notice,
here is a blessing:
  May you do good and not evil.
  May you find forgiveness for yourself and forgive others.
  May you share freely, never taking more than you give.
https://spdx.org/licenses/blessing.html
xsde (version: 3.2.0)
by: Boris Kolpackov
Copyright (c) 2005-2023 Code Synthesis.
xsde (version: 3.2.0) is licensed under the terms of LICENSE AGREEMENT FOR
CodeSynthesis XSD/e SOFTWARE (not disclosed).
GenAPi uses XSD/e, which is subject to a private license agreement between the
GenICam consortium and the original authors of XSD/e.
Under the terms of this agreement, closed-source commercial usage of XSD/e is
permitted exclusively when XSD/e is used as part of GenApi.
This exception applies to software that uses GenApi and, by extension, its
dependencies, including XSD/e.
The full license terms for XSD/e are not publicly disclosed, but are available
upon request.
XSLTProc (version: 1.1.38)
by: Daniel Veillard, Thomas Broyer
https://gitlab.gnome.org/GNOME/libxslt/-/archive/v1.1.38/libxslt-v1.1.38.zip
XSLTProc (version: 1.1.38) is licensed under the terms of MIT.
SPDX id: MIT
Licence for libxslt except libexslt
 Copyright (C) 2001-2002 Daniel Veillard.  All Rights Reserved.
copies of the Software, and to permit persons to whom the Software is fur-
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FIT-
DANIEL VEILLARD BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CON-
NECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Except as contained in this notice, the name of Daniel Veillard shall not
be used in advertising or otherwise to promote the sale, use or other deal-
ings in this Software without prior written authorization from him.
Licence for libexslt
 Copyright (C) 2001-2002 Thomas Broyer, Charlie Bozeman and Daniel Veillard.
AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
Except as contained in this notice, the name of the authors shall not
https://gitlab.gnome.org/GNOME/libxslt/-/blob/v1.1.38/Copyright?ref_type=tags
xxhash (version: 0.8.2)
by: Yann Collet
https://github.com/Cyan4973/xxHash/releases/download/v0.8.2/xxhsum_win64_v0_8_2.zip
xxhash (version: 0.8.2) is licensed under the terms of BSD-3-Clause.
xxHash Library
Copyright (c) 2012-2021 Yann Collet
BSD 2-Clause License (https://www.opensource.org/licenses/bsd-license.php)
Redistribution and use in source and binary forms, with or without modification,
* Redistributions in binary form must reproduce the above copyright notice, this
  list of conditions and the following disclaimer in the documentation and/or
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
https://github.com/Cyan4973/xxHash/blob/v0.8.2/LICENSE
zlib (version: 1.2.8)
by: Jean-Loup Gailly, Mark Adler
https://github.com/madler/zlib/archive/refs/tags/v1.2.8.zip
zlib (version: 1.2.8) is licensed under the terms of Zlib.
SPDX id: Zlib
/* zlib.h -- interface of the 'zlib' general purpose compression library
  version 1.2.8, April 28th, 2013
  Copyright (C) 1995-2013 Jean-loup Gailly and Mark Adler
  This software is provided 'as-is', without any express or implied
  warranty.  In no event will the authors be held liable for any damages
  arising from the use of this software.
  Permission is granted to anyone to use this software for any purpose,
  including commercial applications, and to alter it and redistribute it
  freely, subject to the following restrictions:
  1. The origin of this software must not be misrepresented; you must not
     claim that you wrote the original software. If you use this software
     in a product, an acknowledgment in the product documentation would be
     appreciated but is not required.
  2. Altered source versions must be plainly marked as such, and must not be
     misrepresented as being the original software.
  3. This notice may not be removed or altered from any source distribution.
  Jean-loup Gailly        Mark Adler
  jloup@gzip.org          madler@alumni.caltech.edu
  The data format used by the zlib library is described by RFCs (Request for
  Comments) 1950 to 1952 in the files http://tools.ietf.org/html/rfc1950
  (zlib format), rfc1951 (deflate format) and rfc1952 (gzip format).
https://github.com/madler/zlib/blob/v1.2.8/zlib.h
